Hello,
I have seen the other posts about using flags to create delays prior to code blocks. Is there anyway to create a delay inside a code block?
When Flag Off
THEN DO1
THEN DO2
THEN DO3
WAIT
THEN DO4
I have somfy blinds with a RTS repeater and I find that the HAI sends the commands to quickly for the blinds to actually register if I put more than one in the same code block. If there is no delay function (which there doesn't appear to be) if there some random other function that I can run in the block that'll hold the HAI up for a few seconds?
Thank you
M
When Flag Off
THEN DO1
THEN DO2
THEN DO3
WAIT
THEN DO4
Thank you
M
