Dinkle Terminal Block with Jumper - Distribution Block
  • RAL
Technical Data (UL)
Rated Voltage: 600V
Rate Current: 20A
Conductor Cross-section, Solid (AWG): 22-12
Conductor Cross-section, Flexible (AWG): 22-12
Rated Impulse Withstand Voltage: 6KV
Torque (N-m): 0.4
Screw: M2.5
Wire Strip Length: 9-11mm
Insulating Material: PA
TxHxW (mm): 5.1 x 39.6 x 40.5 (Individual Blocks)
DIN Rail (mm): 35, 32
Jumper/Bridge: Press-fit/Insertion
This assembly includes 10 DK2.5N Dinkle terminal blocks, 2 SS2 end brackets, 1 DK4NC end cover, and a DSS2.5N-10P press-fit jumper, all mounted on a 5" piece of aluminum RoHS rail.  The 10 gauge inputs are all in common.
