$120 Foxconn Intel Atom D525 1.8GHz Intel Barebone System with 2G
standon
http://www.newegg.com/Product/Product.aspx?nm_mc=AFC-TechBargains&cm_mmc=AFC-TechBargains-_-NA-_-NA-_-NA&Item=N82E16856119048
Not a bad deal if you need a small PC with a com port. Just needs a cheap drive and an OS.
Specs:
General
Brand Foxconn
Model R10-D4-DDR3
Color Black & White
CPU Supported
CPU Type Intel Atom D525 1.8GHz
Chipset North Bridge Intel NM10
Memory slot 2 x 240Pin
Memory Type Supported DDR3 1333/1066
Max Memory Supported 4GB
Expansion Slots
PCI 1 x PCI (Only support low profile PCI card)
Storage
Serial ATA 2 x SATA 3.0Gb/s
Graphics Onboard Video Intel GMA 3150
Audio
Channel 6-CH
Communications
Max LAN Speed 10/100/1000Mbps
Extension Bays
3.5" Internal bays 1
3.5" External bays 1
5.25" External bays 1
Front Panel Ports
Front USB 2
Front Audio Ports 2 jacks
Back Panel Ports
PS/2 2
COM 1
LPT 1
VGA 1 x D-Sub
Rear USB 4
RJ45 1
Rear Audio Ports 3 jacks
Power Supply
Power Supply 150W
Physical SPEC
Dimensions 11" x 11" x 3.74"
Weight 10 lbs.
I'm currently using a similiar Atom D510 Foxconn modified a bit with 4Gb, mini raid cage, micro PS for my home automation server (Homeseer). Its been fine since the beginning of the year.
I use the com port for testing but its currently connected to a Digi 7 port USB hub, some USB devices and two Digi 8 port Edgeports (16 serial ports).
Not really dinging the CPU running 24/7.
