Ok, sounds like someone needs an overview of the process to apply the image(s) to the Audrey. Refer to specific instructions available elsewhere for the particular procedures mentioned below. Some steps are critical to those individual procedures. The process is as follows:
Obtain the image of choice from whatever site you wish. Insure the file is complete (don't use MS' size or the size on disk - check the actual Size via Properties). The file should be exactly 16,515,072 bytes. Put the file in the PC share that Audrey can access. For safety, you might want to make it read-only, if it isn't already.
On your Audrey, mount the share. Insure you can see the file from the Audrey mount point. Optionally make a backup copy of the existing Audrey image using the "cat" command to copy the existing Audrey internal flash ROM to the share under another filename. The destination of the "cat" command redirect will be your mount point for the share with a filename appended, such as
Code:
 devb-cf
 cat /dev/fs0p0 /dev/fs0p1 /dev/fs0p2 > /mnt/pcshare/basic.cf
Insert the CF card into the Audrey. Initiate a CF burn to pull the new image file from the share and flash it into the CF card (the destination of the "cat" redirect will be /dev/cf). Check the ending status messages to be sure it was successful. Example:
Code:
 devb-cf
 cat /mnt/pcshare/StockHA.cf > /dev/cf
You may want your machines on a UPS for the next step. If power blinks or dies during an internal ROM flash process, it is possible the Audrey could be rendered unusable.
Follow the procedures to reboot your Audrey and hold down the appropriate buttons to get the Audrey to now update its internal flash from the CF card.
Hopefully, this is successful. If not, Audrey should revert to the original flash image, and you can try again.
Hope this helps.
