I've done a little more research, and it seems to be indicating that the
only solution for a long-term installation requires the solar electricity producing elements to be mounted directly behind clear *glass* and hermetically sealed against moisture. Allegedly, anything other than glass, whether it be polycarbonate or epoxy or whatever, will yellow with time (some materials faster than others), eventually choking off (or at least greatly reducing) the useable sunlight.
Is it true? If so, it seems like relatively few tiny solar panels are built to last very long. I mean, I haven't seen *anything* solar at the consumer level (whether it be simple solar garden lights or whatever) that uses glass. It does seem like consumer grade stuff yellows over and loses functionality, generally in about a year or less, and maybe the lack of glass at least partially explains why it so quickly disappoints and becomes trash. It really is odd that there don't seem to be many (any?) consumer products which differentiate themselves by at least attempting to last longer than the lowest common denominator.
Anyhow, I'm prepared to switch to a low power design to hopefully reduce the solar energy costs to a much lower amount than what was costed-out earlier in this thread, with the hoped-for payoff being no future battery changes. So far, the smallest/cheapest solar panels I've found that use glass are from China on ebay at around $10 plus a 6 week delivery wait, but even then it's a roll of the dice as to how well they're moisture sealed, etc.:
http://www.ebay.com/itm/1-3W-5V-260mA-Tempered-Glass-Mini-Solar-Panel-Module-System-Charger-DIY-CA-/251586862369?pt=LH_DefaultDomain_2&hash=item3a93bedd21 No claims are made about moisture sealing, and it's not even mentioned. Is there a better source? With current low power options, it's possible to build sensors that consume an average of 100microamps or less (some as low as 100 nanoamps or less with extra special effort tweaking the sleep states and waking up only infrequently and very briefly). For instance, you can strip the arduino down to the barest of bones (basically just an ATMEGA328P and a few resistors and capacitors) and achieve it that way. I'm shortly about to do just that (as described here:
http://gammon.com.au/power). It seems we are at the beginning or middle a major trend right now toward ultra low power consumption devices which are to be powered by "energy harvesting," such as solar.
