RAL said:Are you saying that you have a white neutral wire that enters the box, but does not connect to anything else at all, not even a second white wire that exits the box and goes to the light fixture box that is being controlled?
One simple test would be to use your multimeter to measure the resistance between the neutral wire and the ground wire. Make sure the breaker for this circuit is off before you do this! The neutral and ground wire should be connected back at the service entrance. If your meter shows more than a few ohms resistance, something isn't right.
Not sure if you can see much but this is the original dimmer. The neutral is in the back with the red wire nut. I guess the worse case scenario, I can simply have the builder come fix this since it's a new construction.. PITA though..RAL said:> So if something's wrong with the neutral, what do I do next?
If the neutral is not connected, then you need to try and trace it back to where the unconnected point is. The cable in the box where the dimmer is might go directly back to your circuit breaker panel, or it might be wired through several other boxes. You can figure this out by turning off the breaker for that circuit and then testing every outlet and every light switch to see what else is on that circuit. Then start examining the wiring in each box to see if you can find one where there is another unconnected neutral.
It's possible that all the ends will be connected, which would then suggest that there is a real break in the wire hidden in the walls somewhere. That will be a lot more difficult to find.
I'm having trouble picturing how this single gang box is wired. How many romex cables are in this box, and how many conductors are in each cable? By any chance is there just one 14-3 cable with the red and black connected to the dimmer? If so, then the cable probably runs to the light fixture box, and the neutral was left unconnected there.
Work2Play said:Not the clearest shot in the world, but it sure looks normal. Do you have the load out and the hot in reversed by chance?
It's pretty normal in light switches for the neutrals to be tied together in the back of the box with a wire nut. It's also slightly possible you have a bad switch. In that picture though it looks like all the neutrals in the box are tied together, right?
RAL said:I agree with Work2Play, this looks like pretty normal wiring.
On many dimmers, the red wire would be connected to the load (the light), and the black wire would go to the hot wire from the breaker panel. But with some dimmers, they can be wired backwards and will still work ok. So if you didn't check with a multimeter which wire is actually the hot wire from the panel, it's possible that you got it backwards if you just followed the way the old one was wired.
