What does the new software give us? Is it a recommended upgrade?
No joy in the firmware install here. Using both methods of reset the flash program will get as far as the "y/n" after pushing the F1 button, but after pushing the button, the DOS screen disappears and nothing is updated.
You are using the RS-232 port?
Are you using RS-232/USB adaptor?
Paul
Paul has asked that I do not post it... hence you won't see it here.
Any idea as to why?
I am considering buying a 1240, but it appears to me that support seems somewhat spotting at best (just my opinion from casually watching the threads)
It would seem to me that Brultech ought to be encouraging you.....your helping them w/ product support (again, hjust my opinion).
I have put together a perl script which listens to an EtherBee device connected to an ECM-1240. The script works in two modes, server and client.
Server: Listens for EtherBee connections, decodes ECM-1240 packets and writes them to a shared memory segment.
Client: Reads the shared memory segment and can update rrd files directly, print the readings to stdout or relay them to another system. Any number of instances running in client mode can be started.
NOTE: The rrd files must already be created. Given I have my ECM-1240 setup for a 1 second interval, I have individual rrd files - one for each reading.
I hope people find it useful. Since this is my first post here, I'm forced to make the URL a bit cryptic.
Point your browser to
<slash> brultech <slash> brultech.pl
- Mark.
