ultrajones
Anyone know what Brultech will be charging for this software?
Another option is a software serial port splitter like this Serial Port Splitter. A little pricey at $129 but extremely useful. I'm considering purchasing to ease driver development for CQC and doing things like this thread is talking about, 2 software packages, one serial port.
- Ben
Check out this:
http://com0com.sourceforge.net/
Look for hub4com. It allows you to do what you want.
Did anyone notice this in
ECM Engine ver 1.08 Beta
‘View Data’ tab
The legend on the left shows:
CH1 Watt
CH1 Amps
CH2 Watt
CH2 Amps
But the data in the device A column shows
23.4 A
0.1 A
3160 W
9 W
The legend on the left SHOULD show:
CH1 Amps
CH2 Amps
CH1 Watts
CH2 Watts
‘View Data’ tab
CH1 Watt
CH1 Amps
CH2 Watt
CH2 Amps
23.4 A
0.1 A
3160 W
9 W
CH1 Amps
CH2 Amps
CH1 Watts
CH2 Watts
When I attempted to install the Cassini Web Server, I kept getting an Error Code 2869.
I turned off my UAC in Vista and the error goes away.
When I go to http://localhost:9009 the dashboard loads with my circuit names but I never get any data.
Any ideas?
Any ideas?
Is the ECM Engine running and collecting data? You need to start this, get it collecting data, and set it to log to a database (just a checkbox). It took me awhile to get this working. After pulling my hair out for about 15 mins, I power cycled the 1240, and then it started working. I had my 1240 flake out one other time also when I was messing with settings and it required a power cycle that time also before it would start sending valid data again.
I ran into the same problem, the first version filled that in automatically, but for some reason this one did not, to resolve it I simply re-installed the first one copied the product key down, uninstalled it and reinstalled the newer version. I don't want to post the key in case it is unique to each system, or if Brultech does not want the keys posted.Installed both the new Engine and Dashboard, but the Dashboard now wants a "Product Key"...
I am guessing once Paul reads this he will probably release a new version with the key integrated or post the key on the website.
Geoff
Any ideas?
I found Brultech has posted an updated version of the ECM Engine. Version 1.11.
It fixed the problem with not being able to save the cost per kilo watt and added a database write status.
Yes, I verified my ECM engine is logging to the database.
I will try the power cycle.
