Here's a quickie snapshot from a reasonably priced (<$200) 1.3 MP IP camera I've been playing with. Software needs some adjustments still.
Image Compression
H.264&JPEG
Image Sensor
1/3" 1 megapixel CMOS
Lens
3.6mm lens
ICR function
Support,36pcsф8 IR leds(3.6MM/6MM)
Support,20pcsф8+4pcsф25 IR leds(8MM/12MM/16MM)
Minimum illumination
[email protected] ,0Lux@IR-cut On
IR Distance
5-20meters
Sensitivity
1.0V/lux-sec (550nm)
Video Resolution
Primary stream:25fps @ 1280 x 720,1024x768,800x592,800x450, 650x480,640x368, 480x368,480x272
Video Bit rate
256 Kbps – 8 Mbps
Audio Compression
PCMU/PCMA
Network Connector
10M/100Mbps self-adaption , RJ45
Network Protocol
TCP, UDP, IP, HTTP, DHCP, RTP, RTSP, FTP, SMTP, DNS, DDNS, NTP,ICMP, IGMP, ARP,SIP
DDNS
YES
Working Condition.
Temperature:-10°C ~ +50°C Humidity:10%-90%
Power Supply
DC12V
Image Compression
H.264&JPEG
Image Sensor
Lens
3.6mm lens
ICR function
IR Distance
5-20meters
Sensitivity
Video Resolution
Video Bit rate
256 Kbps – 8 Mbps
Audio Compression
PCMU/PCMA
Network Connector
Network Protocol
DDNS
YES
Working Condition.
Power Supply
DC12V
