felixrosbergen
I am just curious if and when these guys actually slow down or stop if not in use.
I have a 500GB as primary Win2k3 server drive (so i don't expect that one to sleep) and a 1TB one for SageTV video storage. The 1TB drive i would expect to but off most of the day unless i'm recording or watching something.
Is there an application of some sort that woudl tell me when these drives are sleeping?
overall my Cure2Duo 3.16, 2GB RAM, Hauppage 500 machine on Antec NeoPower 430 uses consistently between 80 and 65watts according to KillaWatt, thats a lot better than my previous server which used nothign less than 180 watts.
The CPU throttling software (Gigabite mobo) seems to be able to reduce the power draw be another 3 watts or so. Hardly worth loosing performance over. I was hopig to get it down more, but no luck so far. This machine runs very cool and i am thinking about replacing the 120mm and 80mm case fans with mobo controlled or sensor activated ones. Especially the 120mm fans probably draws a good bit.
Is 80watts pretty normal for a performance machine built with energy efficency in mind?
This thing will be on 24/7 running SageTV and CQC so if i can cut another 10-20 watts somehow that would be very good over the years.
Right now 80 watts (at almost unity power factor) would me about 50 cents a day or US$15/month, $180/year to run. On an annual bases every watt I save woudl equate about $2.
