simplextech
I finally went in and bought a Elk M1G and 2-way wireless and 319.5 wireless setup along with some other goodies (Lutron integration), etc etc....
In the setup and testing I'm having "weird" results from the wireless contact sensors. I've tested with the ELK-6020, ELK-6023 and with Interlogix (EcoLink) TX-E201 and TX-E251. I think I can rule it out being one sensor type or one wireless type between the Elk 2-way wireless and the 319.
The issue is the response from the wireless sensors is erratic/spotty. Sometimes the response is perfect but most of the time there's a 1 - 3 second delay in the response to the contact opening. I've tested this with Elk rules directly to the RR2 main repeater to turn on a light and I've tested it through my control system and the result is the same. Sometimes perfect but most of the time really delayed.
On the 2-way sensors I can see the LED flash green when testing and I can see the delay directly at the sensor LED.
I've moved the transceiver to a new location and tested and same results. I've even tested standing in the same room as the transceiver and it's the same results.
Everything is connected via CAT5 with a data bus hub. I went and checked everything to make sure the termination of components was correct and they are.....
I'm at a loss of what to check/try next and was hoping someone here might have some ideas.
