Keep getting an Unhandled Expection Error in RP 2.0.6
I discovered it probably more than it is an error, see below for the report probably more or ELK than anyone else. The way I can trigger this error everytime is double clicking M1XEP button on the "Accounts Details" page. (Bottom right hand corner) the button that takes you to the "M1XEP Setup" utility.
I realise that double clicking the M1XEP utility is not required to open it up only one required, I accidently did it. If choose "Continue" the error message disappears and you can continue using RP no problems.
I am running Windows 7 64bit.
Interested if other folks re getting the same.
Regards,
Fleetz
Error message follows..........
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.InvalidOperationException: Form that is already visible cannot be displayed as a modal dialog box. Set the form's visible property to false before calling Show.
at System.Windows.Forms.Form.Show(IWin32Window owner)
at M1G.Account_Details.M1XEPsetup_Click(Object eventSender, EventArgs eventArgs)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.4952 (win7RTMGDR.050727-4900)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
ElkRP2
Assembly Version: 2.0.6.27193
Win32 Version: 2.0.6
CodeBase: file:///C:/Program%20Files%20(x86)/ElkRP/ElkRP2.exe
Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Microsoft.VisualBasic
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.4927 (NetFXspW7.050727-4900)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
AxInterop.PVExplorerLib
Win32 Version: 8.0.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/ElkRP/AxInterop.PVExplorerLib.DLL
MSDATASRC
Assembly Version: 7.0.3300.0
Win32 Version: 7.00.9466
CodeBase: file:///C:/Windows/assembly/GAC/MSDATASRC/7.0.3300.0__b03f5f7f11d50a3a/MSDATASRC.dll
CodeBase: file:///C:/Program%20Files%20(x86)/ElkRP/Interop.PVExplorerLib.DLL
Microsoft.VisualBasic.Compatibility
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualBasic.Compatibility/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.Compatibility.dll
Accessibility
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
Interop.ELKCOMMLib2
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/ElkRP/Interop.ELKCOMMLib2.DLL
ADODB
Win32 Version: 7.10.2346
CodeBase: file:///C:/Windows/assembly/GAC/ADODB/7.0.3300.0__b03f5f7f11d50a3a/ADODB.dll
ElkSafe2
Assembly Version: 1.1.6.17695
Win32 Version: 1.1.6.0
CodeBase: file:///C:/Program%20Files%20(x86)/ElkRP/ElkSafe2.DLL
ConvertDB2
Assembly Version: 1.4.6.17696
Win32 Version: 1.4.6.0
CodeBase: file:///C:/Program%20Files%20(x86)/ElkRP/ConvertDB2.DLL
Interop.Scripting
CodeBase: file:///C:/Program%20Files%20(x86)/ElkRP/Interop.Scripting.DLL
Interop.ADOX
Assembly Version: 2.8.0.0
Win32 Version: 2.8.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/ElkRP/Interop.ADOX.DLL
System.Xml
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
Interop.JRO
Assembly Version: 2.6.0.0
Win32 Version: 2.6.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/ElkRP/Interop.JRO.DLL
EZ82
Assembly Version: 5.0.6.27183
Win32 Version: 5.0.6.0
CodeBase: file:///C:/Program%20Files%20(x86)/ElkRP/EZ82.DLL
M12
Assembly Version: 5.0.6.27189
CodeBase: file:///C:/Program%20Files%20(x86)/ElkRP/M12.DLL
M1G2
Assembly Version: 5.0.6.27186
CodeBase: file:///C:/Program%20Files%20(x86)/ElkRP/M1G2.DLL
System.Data
CodeBase: file:///C:/Windows/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
ElkWords2
CodeBase: file:///C:/Program%20Files%20(x86)/ElkRP/ElkWords2.DLL
RPClassLibrary
Assembly Version: 1.0.6.17695
Win32 Version: 1.0.6.0
CodeBase: file:///C:/Program%20Files%20(x86)/ElkRP/RPClassLibrary.DLL
ElkIPv42
CodeBase: file:///C:/Program%20Files%20(x86)/ElkRP/ElkIPv42.DLL
System.Web
Win32 Version: 2.0.50727.4955 (win7RTMGDR.050727-4900)
CodeBase: file:///C:/Windows/assembly/GAC_32/System.Web/2.0.0.0__b03f5f7f11d50a3a/System.Web.dll
System.Configuration
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Regards,
Fleetz
mscorlib
ElkRP2
System
System.Drawing
MSDATASRC
Accessibility
Interop.ELKCOMMLib2
ADODB
ElkSafe2
ConvertDB2
Interop.Scripting
Interop.ADOX
System.Xml
Interop.JRO
EZ82
M12
M1G2
System.Data
ElkWords2
RPClassLibrary
ElkIPv42
System.Web
enabled.
For example:
<configuration>
</configuration>
