wkearney99
While things can be made to 'meet code' something like that violates the "principle of least surprise".
I doubt anyone coming along in years hence will be expecting there to be a full outlet buried behind a speaker grille!
That's my point here. I'm saying I wouldn't do it that way, nor recommend anyone else doing so. You're clearly free to entertain other ideas. It's certainly clever, in a hillbilly-kinda way. So, points for ingenuity!
I think code would suggest using an actual work box designed for a line voltage outlet and then in-wall low voltage cable run to an actual speaker. Someone coming along later sees a speaker and finds it's just a speaker, finds a workbox access plate and sees there's equipment installed as per code.
Although, I suppose something could be rigged up in the same fashion, but the outlet faceplate would have to be flush against the inside of the 'alcove'. Effectively isolating it from the low voltage gear in the box.
