Bzncrewjr
sau said:All general home wiring (romex) have a white, black and bare wire, but that doesn't mean they are always attached to the neutral power feed from the breaker box. The most common annoying case is that power is wired to the light fixture first and then only the hot (black) continues on to the light switch and back to the light on the white wire to form a loop. The problem is that at the switch you only have one dead lead (white wire for return power/closed loop) and the hot black wire and no real neutral. I believe electricians are supposed to black tape the wire wire to indicate it is technically a hot return and not neutral. Without actual hot and neutral at the light switch, you won't have any power to operate a upb or zwave light switch.
What you hope would be done is power goes to the light switch first, and then up to the light switch ensure both hot, neutral and load wires are there at the switch box. 3-ways get more complicated but as long as power goes to the light switch first you're ok.
I lucked out and only had one switch that lacked a neutral (aka common) but thankfully it was in a multi gang box and the other switches there had a neutral I could use.
To understand what your requirements for UPB are, you could technically get away with using all master switches, you don't actually need slaves in 2,3,4-way lighting. Slaves are simply cheaper. That being said, there isn't a whole lot of value in spending the money needlessly either. Slaves chain off the master in a multi-way lighting setup. In a basic 3-way, you need one master, and one slave. There can only be one master because a master switch is what actually turns on and off the light, the other switches just tell it to. The wiring gets a bit complicated but that is where you would need a multi-meter and the instructions and a clear head.
Good luck!
Thanks for the explanation Steve. That makes things much clearer for me. Essentially I need power at the switch for it to operate.
Electricians were wrapping up today when I went out there. I'll go back out there Monday and have a more in depth conversation with them.
--Russ
