Hello rossw - TY for example!
So, I don't see any MOD command nor CTS (there is a CS, most likely same thing)? I have WC8 (I have been reading WC32 manual to get extra info and realized it does have more commands in PLC language).
Also, getting something to start and stop between START and END I have been able to do, but for some reason I can not get out of a SUBROUTINE. In other languages I am used to something like DO...WHILE, can't figure out how to do it here.
And, this is my second attempt to understand non-binding timed commands (tried back in May as you probably remember) and still am not understanding how to make best use of it.
WIll spend some time reading through LarrylLix's sample to see where my mind is going wrong after I fix my hot water heating system which sounds like a screaming hyena.
I think in my code, I have to change the use of the timed command:
From SET OP8[3000] 1
To TSTEQ OP8[3000] 1
and have the next statement somehow get out of the loop, hopefully by being able to change the RAM1 flag - not sure what gets out of the loop.
Rainer
