wdeertz
I'm using a UPB Simply Automated UCQF-W fan controller that I need help configuring. I have the switch wired and the high/medium/low/off physical buttons work fine and I can send UPB links to turn on/off the fan (both with buttons and the standard UPB links). I have the correct UPB links programed for the HAI HLC control so when I turn on or off the room the fan comes on and turns off but I can't turn on the single fan by itself using the unit on/off button. See the attached screenshots from within Upstart which show my current settings. I've left the fan as UPB unit ID 52 which is the default.
What UPB link is sent when you send unit on/off? Any help so I can turn on/off the fan simply by using the on/off command would be appreciated.
