Ok, to start this off here is what I purchased: Leviton Z-Wave 15 Amp scene capable switch - model# R02-DZS15-1LZ
To start I purchased 4 of these to add to my Wink Hub. I wanted to install the first 4 and keep buying more from there until I have most of my home completed.
I first started with a 3 gang box of switches. The first switch I swapped out (not a 3 way) was for my front porch light but I seem to be having issues with getting the switch to even turn on the light. Yes, I do have neutral wires for each switch that were tucked away in the back of the box. Once I had the switch installed the green led at the bottom comes on but when I try to turn on the light I get nothing. Also, the switch to the left of this one didn't work once the switch was installed. The switch to the left is 3 way with the other switch being at the top of the stairs.
I am at a complete loss on why this is happening and why it would disable the other switch once installed. Plus, I can't understand why the switch has power but won't turn on the porch light once installed.
Any advice or guidance would be appreciated.
