86turbodsl
We have a generator subpanel and portable generator, but the heat isn't wired into it. That's what the fireplace is for, mainly. It adds heat during the colder days of winter, but it was mostly thought of as our most emergency-type heat.
I have an air to air exchanger, I guess you'd call it. There's the big unit outside that gets the heat from the air, and then it brings it into the inside unit where the fan is.
Not varying during winter is part of the reason I'd like geothermal, because like I said...when it's down in the single digits downstairs, I see upper 70's for duct temps, but when it's in the 40's, it's closer to 100.
If the geothermal is always exchanging with water that's around ground temperature (around 50 deg or so) then I guess I don't understand why it'd have to run all the time, or wouldn't even be able to keep the house warm. Isn't that more than enough heat coming out? If my air exchange heat pump can produce 100 deg of heat from 40 deg air, I'd think a ground exchange would do even better with 50 deg water.
Depending on if you have a horizontal ground loop or open loop system, it's a misconception that the ground can replenish the heat as quickly as you can pull it out.
When it was real cold last month, I put a thermocouple into the supply loop to see what the delta T was running, and even though our ground temps here run about 50F at 6' depth, my water supply temps were about 34F or so.
That's typical for end of season in my opinion. My feeling is that you probably lose a bit of capacity as the winter goes on. I'll work on improving the tightness of my house over this year and hopefully keep up a bit better next year.
Meanwhile, I'm using propane to supplement.
