[How-to] Build an Antenna for Your X-10 Receiver
I would suggest that you first get the ninja plug-in going. It opens up a whole new world for the ninja. And the ninja bases are currently onsale at x10 for 3 for $78. A great deal! (although I would hope that Martin could improve on this too!)
Jeff, have you considered trying to hack the ninja and putting an antenna on it? Has anyone?
Also, it the camera on the flaky ninja wired or wireless? If it's wired, I wonder what would happen if you "injected" the CM19's signal into the same cable at the video signal, then split the signal at the ninja end, with one end going to the cam and the other either to a little antenna, or hardwired into the ninja?
I have found a hack for the ninja - putting an antenna on the base unit. I haven't tried it, but here it is ninja base antenna hack
I have only used a wireless X10 camera - and I still don't think you can beat the price/value. You could mount any type of camera on the base though. One note: the ninja base must be "ON" to accept commands and move.
Interesting thought on the wired cam idea - I am not adventurous enough to try that - but let me know if you try and how you make out!
Wow, I just put this antenna on my W800 and I am VERY impressed with the range I am getting (at least doubled over my MR26a).
I can't do a comparison of antennas (one that came with the W800) because the antenna I made is in my attic and I just connected the cable that originally went to my MR26a to my new W800.
How does the thickness of the rod effect reception? (only asking b/c got a free 1/4" rod from a radio shack store closing) I have room to mount it if it will do the job. If not I guess I could pay money for the right one.
Rewdi
I'm guessing it should work out OK! I'm not an expert, but I'm thinking as long as the length is correct I don't see why it would not work out.
Uh, so I looked at my post again this morning, and looked at the rod... it's actually 1/2" copper, do they make the ring crimp lugs that big??? and if so would they still fit on the Adapter?
Just a random thought.
Rewdi
I have a question for all of you RF experts. Does the choice of materials affect (improve/degrade) the performance of the antenae? For example, will 1/8" rod work better than 1/16" rod? Will copper work better than brass? Also, when using the antenae for a transmitting cm19a (to control Ninja pan) - are there any optimizations that can be applied?
/Jimboat
Now Jeff....
You have made things far too easy.... Here is the code that I use a button:
<td width="156" height="22" align="center" bgcolor="#77AFF1" style="border-left-style: inset; border-left-width: 4px; border-right-style: inset; border-right-width: 4px">
<img border="0" id="img11" src="Images/ultimate/lowres/button39.jpg" height="20" width="140" onmouseover="FP_swapImg(1,0,/*id*/'img11',/*url*/'Images/ultimate/lowres/button3A.jpg')" onmouseout="FP_swapImg(0,0,/*id*/'img11',/*url*/'Images/ultimate/lowres/button39.jpg')" onmousedown="FP_swapImg(1,0,/*id*/'img11',/*url*/'Images/ultimate/lowres/button3B.jpg')" onclick="camera(7);I1.location.href='placeholderb.htm'" onmouseup="FP_swapImg(0,0,/*id*/'img11',/*url*/'Images/ultimate/lowres/button3A.jpg')" fp-style="fp-btn: Embossed Capsule 1; fp-font-size: 8; fp-font-color-normal: #000080; fp-font-color-hover: #FF0000; fp-font-color-press: #FFFF00; fp-bgcolor: #77AFF1; fp-proportional: 0" fp-title="Cat Cam"></td>
:lol: :D :p
/Jimboat
The diameter will do almost nothing except possibly make the antenna a little more wideband. No difference in materials.
I built this antenna according to your plans and it works great. With the antenna hung from the cieling of my computer room my little key chain remotes will reach the middle of the street with no problem. No reason to put it in the attic except for aesthetics.
http://www.cuebuilt.com/viewonly/img_0020.jpg
My question: A friend wants me to build him an antenna, but doesn't want it mounted like mine. Can I mount it upside down with the single rod pointing up and the ground plane rods pointing down with the coax running up through a piece of PVC pipe so it resembles a floor lamp? Will the signal be degraded?
Bill
[quote name='Rambler'
Bill
[/quote]
Bill,
That should work fine also.... I used an antenna of this style mounted the same way in a diffrent frequency band for years
Bill
[/quote]
Bill,
