Desert_AIP
If you issue a timed light command, at the expiration of the timer the system issues the inverse command.
So if you issue a BRIGHT 60 FOR 5 MINUTES
at the end of 5 minutes the system will send a DIM 60 to put the lights back where they were.
I Dont recall if you can also send a timed level command with a fade rate specified
Play with a bit and I can test something's tomorrow
