chrishallowell
I got the prototype working perfectly. Thanks Frank for all of your help.
Chris
Chris
the measurements were 4.12 VDC and 2.12 VDC
I am getting 7.5 and 9.2. I am trying to connect it to M1xin but since I need analog, I might have to move it to the main board. I will give it a try. ThanksWhat do you have the zone type as? Note in electron's article he stated the difference between "on" and "off" was:
What voltages are you getting? You may have to set the Elk zone up as an Analog type and write rules to see if it is say above 3.5 volts or below 2.5 volts.
Which polarity did you plug your wire from LED light (via photoresistor) to input zone? If you have your wire plugged into positive polarity, perhaps you need to hook up the wire to negative.
You will need to use electrical tape to isolate the light
Not following;the HDExtender is always "on", just in standby mode. Not sure if it draws significantly less current in standby, is that what you're talking about?I think you would be better off with a CR magnetics current sensor
