ccmichaelson said:So I walked around the house looking for a better DC option and recalled that I have a battery connected to my existing home's alarm panel. It is a UB1280 that says "12V 8Ah" on the side (except it doesn't say where it's AC or DC - I'm sure smart people would know...I am clueless). Could I connect my 22 gauge alarm wire to this battery to power my motion sensor (just for testing)?
I'd still recommend the battery and a couple of .250 F1 connectors and call it a day. Maybe a fuse on the positive if we were being extra cautious. I think, in the case of a prewire, it's the safest option. Nobody mentioned the need for 120VAC and whether or not the extension cord would be grounded and connected to a GFCI. That's a heck of a lot more dangerous than a DC battery if I were to choose between the two.RAL said:If you don't feel comfortable with this, then I'd recommend using the 12V wall wart instead. At 15V, it's right on the edge of being acceptable, but it will not be able to deliver a potentially dangerous amount of current like the battery can. The wall wart probably won't blow up the detector, even if it is a little bit over 15V. You'd be trading one risk (that of a short that could result in injury to you), for another, probably lower, risk (that of damaging the detector).
Probably this is old news for many here...but would you mind explaining the compromise?DELInstallations said:...You need to determine what is important, verified capture performance or more sensitive PIR performance that may cause falsing in the hopes of being able to use a single detector for both security and occupancy (which will always be a compromise and have lackluster performance on both). ...
Ano, this is not true. Anyone that has spent any time in the field installing and servicing would disagree with you. If that were the case, you'd need to look at the progression of the PIR's over the years and what detection had been added to help eliminate false alarm problems, all the way up to today with a ton of extra chips to filter the pyro element signatures. Same holds true with detectors installed in hot or hostile enviroments. Care to guess how many PIR's don't capture with 100 degree heat or high heat items in their pattern (or false) yet a PIR or RCR detector works fine?ano said:PIR+Microwave will be slower because both need to trip before the zone trips. Tech support likes them because they cost more.
To prevent false alarms read about the "cross zoning" feature and turn it on. Then add lots of motion detectors and add them alll to cross zoning. No false alarms and good motion detection for lighting control.
