SteveInNorCal
My Elk M1G installation is nearly complete; sensor wiring is completed and wrung out. The system arms and disarms correctly. Outputs 1 and 2 working correctly. The system includes three Blue Line Gen2 TriTech Motion Detectors which light up the blue LED whenever a person walks into the detector coverage area. I haven't seen the detector LED go on when our three pets are walking around, jumping onto chairs, etc, but I'm concerned about them causing false alarms. The Bosch Blue Line are supposed to be very pet-immune, but I want to test this out rather than listening to marketing hype.
I'd like to run the system for several days to test for pet-caused false Motion Detector alarms before placing the system into real service.
Is there a way to prevent Output 1 and Output 2 speakers from sounding during such a test period? In other words, can O1 and O2 be temporarily turned off in the configuration?
Or should I simply disconnect O1 and O2 (and replace O2 with a 2200 Ohm resistor to avoid "Output 2 Trouble" on the keypad)?
Does the unit log capture all sensor trip events while armed?
