pete_c...not sure I completely understand.
Are you saying I can stick with a single static IP address for the WAN, leave the wired router connected to the DSL modem like it is today, then connect the wireless router to the wired router (also like I have it today)? So all devices connected to the wired router will have 192.168.1.nnn private IP addresses. All wireless devices will have 192.168.2.nnn private IP addresses. Then I set up rules to allow the wireless LAN devices to get to the internet thru the wired router, and to the printer on the wired router? If so, are the rules set up in the wireless router or the wired router? I haven't done much with routing rules in the past.
If the above is what you are suggesting...what does that configuration buy me over one using the switch between the DSL modem and two routers (one wired, one wireless), and the routers using different static WAN IP addresses and different private IP addresses behind them?
My wired router's private IP address is 192.168.1.1. The wireless router is 192.168.1.2. Do I change the wireless router to 192.168.2.1?
On a positive note, I did get WPA2 set up and working on the wireless side.
I do plan on using SSL VPN for my personal wireless devices to get into my wired network. For the companys' VPN access, I don't have any choice but Cisco's VPN client. It's interesting how many companies still use it. For a long time, Cisco said they would not ever provide support for Windows 64-bit machines for their VPN client and that 64-bit users had to use their AnyConnect VPN client. I guess a lot of their major customers complained because now they have support for Windows 64-bit in the old client.
Ira
Ira
