Hello everyone, this is my first post, but have been reading on this forum for a long while.
I am having problems getting the integrating monoprices 4x2 matrix switcher (pid 5312) to the HAI Omni pro 2.
The switcher has a db9m port for rs232 control.
I am trying to build a custom rj12 male connector (hai serial port) to a db9 female (switcher side) custom cable to control it from the Omni
The documentation says "this cable has the pins 1-9 all straight through, except for pins 2 and 3 which are crossed."
The rj12 male connector has 6 pins and the db9 female has 9 pins. What are the pins assignments?
rj12 male connector pin to db9 female connect pin
1 x
2 x
3 x
4 x
5 x
6 x
x
x
x
I have also placed my the config in pc access with serial port 2 set to prolink and buttons defined (eg TV1 INPUT3)
WHEN TV1 INPUT3
THEN SEND 02 fd d5 7b^M OUT SERIAL 2
[SIZE=10pt]I have used the hex codes for serial control provided from the 3 sites.[/SIZE]
remotecentral.com/cgi-bin/mboard/rs232-ip/thread.cgi?114,2
monoprice.com/Product/?pg_no2=5&c_id=101&cp_id=10110&cs_id=1011002&p_id=5312&sortby=&period=&rating=3&seq=1&format=4#
monoprice.com/Product/?pg_no2=10&c_id=101&cp_id=10110&cs_id=1011002&p_id=5704&sortby=&period=&rating=&seq=1&format=4
I have tried using a monoprice null adaptor db9 male to female and a dsc it100 serial cable to get control but it didnt worked.
I have been struggling with this for weeks to no avail. Can you please help?
Thanks very much !!
1 x
2 x
3 x
4 x
5 x
6 x
x
x
x
WHEN TV1 INPUT3
Thanks very much !!
