Found this while googling tonight....
http://www.homegenie.it/
HomeGenie Do It Yourself Project 2.8" TFT Touch Panel for Home Automation
Using a Raspberry Pi , like we already did in the DIY Home Automation Server project, we're now going to build a TFT Touch Panel for our Home Automation system based on HomeGenie.
HomeGenie Touch Panel Components Listing
The software you see in these screenshot (HomeGenie Smart Control) is still under development and it will be completed by the end of June 2014.
It is currently built for running on any 320x240 Touchscreen Display.
The final relase will come on a prebuilt SD-Card image with pre-configured drivers for Adafruit TFT Touchscreen and automatic startup of HG Smart Control, so the only thing needed to make it run it will be writing the SD-Card image.
In the meantime you can already try setting up current version of HG Smart Control by following these steps:
http://www.homegenie.it/docs/doityourself_touch.php
- Raspberry Pi
- Adafruit 2.8" 320x240 TFT Touchscreen
- Mini Wi-Fi USB module
- 4GB SD Card with HomeGenie server + HomeGenie Smart Control client
- Small 5V power supply
- Flush mounting junction box 120x100x70
