Well, the blog ain't working for me, so I guess I'll keep it here for now.
Ok, this is what I've tried since the last freeze:
1) Rebooted to bios, checked the cpu temps. Perfectly fine. Also set a shutdown temp of 65C, so it should shutdown, not freeze, if its a cpu issue. CPU fan works just fine.
2) Ran the MS memory test I've got. Let it run for over an hour, no errors found.
3) Checked all the system logs. There were a few issues, something about a serial port type error, and also something about "it shut down abruptly", which Im guessing is the freeze (Im thinking it notices when the PC comes back up that it didn't get to save it's normal data out or something like that). I cleared all the logs so if it freezes again I'll know it's all stuff that's happened since then.
4) Changed out the power supply.
And the result?? It lasted about 24 hours. This problem seems to be happening a lot more frequently, which again points to the idea of a hardware problem. I wonder if the caps got bad enough to damage something else....
Other than checking the discs, I'm thinking the only thing left to try is a complete system reload. I think I'll throw in a spare hard drive, just load WinXP on it, and let it sit there and run for a while. If it freezes up from that, I know it's not the software, and it would HAVE to be motherboard-level hardware (since I'd have removed all the disks too.) Ya, that seems the quickest way to discern the issue.
