The amperage draw will be the higest when you turn it on depending on the 12VAC draw or load.
With a direct connection to the circuit and just turning on and off the breaker my basement lighting would flicker. You could also utilize an amp probe and do the same. If you only have a few 12VAC lamps drawing then it will not be an issue. If you go the maximum capacity (900 watts) of the toroidal transformer then the amperage draw will be highest when you turn it on.
Even though the variety of appliance switches were rated at XX amps they tended to trip the breakers (my breakers) no matter what (which I could really never figure out). Best to give it a try with some applicance switch (give them all a try; they are relatively inexpensive) rated at XX amps first. As I stated above only the very "old" legacy X10 appliance switch worked for me.
Reflecting a bit now on what I wrote; I was trying to do the landscaping lighting automation stuff inexpensively without really spending $100 (or more) per switch per transformer. That said I learned a bit doing similiar with the chandelier lighting (also purchasing a chanelier "lift" and installing it in the attic - expensive and a pita effort as the device weighed more than my garage door opener (think it was around $700 and the labor to install it would have probably been around $300?) and I had to run a separate circuit for it and spending more than $100 for a UPB PCS switch with some big heatsinks on it; then later automating the multiple cans in the kitchen trying to keep the automation switch costs low; then learning that I really did need a high amperage switch for the 8-10 cans or so it was turning on).
The if you really don't want to play around with this stuff is to go with something like a high amperage switch independant of the controling voltage switch or maybe even better would be a 30 AMP load control switch like the attached links. I went to four of what you purchased and four separate switches on four separate circuits and breakers.
I used a variety of toroidal transformers and most of them were large with big footprints. (multiple voltage taps and circuits). My favorite was the first one I installed which didn't have multiple voltages but had multiple circuits each with breakers in a small fooprint box (difficult though to work in). It was the most expensive one though. The last one I installed before going to the LED lighting was one made by Vista lighting (bought one for me and two for my sister).
http://q-tran.com/
http://www.vistapro....catid=4&typid=7
Here are examples of load control switches (just google them really quick here).
The first link is a UPB switch, next is Insteon and then Z-wave in no particular order.
http://www.homecontr...&category=73338
http://www.insteon.n...troller-NO.html
http://store.homesee...e-P407C246.aspx
http://q-tran.com/
