Listing of CGI commands
rfeyer
With the help of several, most recently LarsK, i am now able to communicate with WC8 not only via Linux but also VB (again, with LarsK's help today).
Q: Is there a listing of all the cgi commands anywhere?
I have been using gett1-8 with Linux to get temp and humidity reainsg (I think humidity was geth1.cgi - going by memory).
what about the rest? I would imagine there are cgi commands that allow the changing of TTL values?
Or the canging of variable and UROM's?
Rainer
You will find most cgi command in the WC8 manual. There are some more, I will have a peek inside my sourcecode.
Another way of sniffing the commands is using FireFox using Firebug.
Here is my list:
geta1.cgi 'Analog
geta3.cgi
geti1.cgi 'Digital
geti8.cgi
getvar1.cgi '32Bit Output
getvar8.cgi
geth1.cgi ' Humidity
gett1.cgi 'Temp
gett8.cgi
getts1.cgi 'Temp status
getts8.cgi
geto1.cgi ' TTL Output Status
geto8.cgi
getcounter.cgi ' Counter Value
getfcounter.cgi ' Frequency Value
Hope this helps!
If you're after more than a few, I find it easier to use getall.cgi and simply parse the results.
what about getall? the standard with other boards is a json reply with all variables and settings...
