I am in the process of wiring my Elk M1G as retrofit in my home and have some questions regarding the general routing of low-voltage (LV) conductors and cables.
I understand that LV wiring should be kept away ( >1 feet) from high voltage 120/240V AC lines when running parallel, and must cross perpendicularly.
However how do you treat the bundling of different types of LV cables? I thought there would be no problems, until I read in some footnote in the M1G installation manual that "power-limited" conductors can't be run next to "non-power-limited" conductors (i.e. the battery leads going into the panel board) - there needs to be a minimum 1/4" separation or airspace between LV-limited and LV-non limited wires, despite these all being ~12VDC in this case. (see page 68, L520 Rev. J 10/28/10 manual)
Now then, do I have to be concerned with separating low current and high current LV wires? Data-comm cables and voltage only cables? I foresee having to run (as a bundle, in wire duct, or in conduit) any or all of the following types of LV cables at some points in my installation:
2c/22 sensors,
4c/22 sensors+power,
4c/18 firewire life-safety detectors,
4c/18 or Cat6 databus components,
Cat6 ethernet LAN,
Cat6 POT,
2c/16 (or greater) speakers/sirens/strobe,
2c/14 (or greater) remote VAux 12VDC power
Here are a couple of scenarios I'm considering:
1. I plan to mount a remote can in a bedroom area linen closet in which there will be a zone input expander and output expander, along with aux 12VDC power. (Since there is no AC receptacle in this closet I can not put a local power supply in this can.) Point run to this can will be smoke, heat, CO detectors as well as a few burglary sensors and a keypad. Outputs may include a strobe or speaker. Between the main panel in the basement and this remote can, I will run a 4c/18 cable for databus, and 2 sets of 2c/14 for SAux (switched and reversible for the smokes) and for unswitched VAux. Any problems bundling these 3 cables for the run between the cans? Are the SAux and VAux conductors considered "power-limited" if the power is sourced from a P212S supervised power supply (which has its own battery back-up)?
2. In a hall closet I will install a wire duct to run LV cables between the basement, main floor, and attic. In this closet I will also mount a wireless receiver for interfacing with some wireless sensors. There will be many wires bundled in this duct for sensors, databus components, aux 12VDC power, speakers, and a siren mounted in the attic vent. I may also route Cat6 for GigE LAN and RG6 for video via this wire duct. Any problems bundling all these different types of cables within the same vertical duct?
My concerns for problems include interference, data transmission reliability, signal quality, besides electrical safety.
Thanks for your insight.
2c/22 sensors,
Cat6 ethernet LAN,
Cat6 POT,
