Efried
Being in a position, where the main controller will be upgraded from WC8 to WC32 I'm experiencing lack of roll out support again. In the best case a drag and drop solution should allow to transfer code from one WC to another while keeping the references to the measuring points.
example:
Using T1 directly will be replaced by a WEBSET of WC1 from T1 to VAR1 at WC2, while the programm on WC2 will then use VAR1 instead of T1...
The good point is while altering, I might update firmware finally...
example:
