I have a hallway that I need to protect, and right now it looks like the best option is a motion sensor. At one end of the hallway are an entrance door with glass, and a window. About 12 feet away, I have a pre-wired box mounted in the ceiling, which is 8' high. The house is finished, and pulling wiring to any other location in the hallway would be difficult at this point, plus there's WAF to consider. And the other end of the hallway is open to a room, so putting a detector on the wall at that end isn't an option -- there isn't any wall.
So I'm stuck with the ceiling mount location. Plus, we have a cat. From what I've read doing searches here, manufacturer claims aside, the only truly cat immune motion detector is one that only covers heights above what the cat can reach.
Given that, I'm having difficulty finding a motion detector that fills the bill. What I have in mind is a beam detector that has a flat fan pattern, that I can aim downwards at an angle so it hits the end of the hallway at a height about 4 feet; that should be low enough to detect any adult who enters, but is above what the cat can reach (there's nothing at the end of the hall for him to climb on). It needs to fit fairly low profile to the ceiling, which is where I'm running into the problem. All of the beam detectors I've looked at are intended for wall mounting, and can only be used on a ceiling with a bracket that hangs down. That probably won't meet the WAF criteria.
Since I can't find anything like that, I'm considering taking a flyer on the Visonic DUO 240. It's a dual technology ceiling mount. It has a 360-degree pattern, which isn't needed in this application, and I'm a bit concerned the microwave could penetrate the exterior wall and cause falses. But since I can't find what I think I need, I may try it and just see how it does.
Anyone got any better ideas?
