http://www.carrier.com/homecomfort/en/us/products/controls-and-thermostats/product---thermostats-and-controls---systxccitc01/ano said:Do you have a link? I tried "SAM" and "Serial" in their search box without much luck.
You'd be amazed. The chiller lines and ice are housed in super insulated containers, like a stainless oil tank with an inner bladder/tank, if you've ever seen them. The engineering I saw stated somewhere around a 20 hour time with zero input from the outside.ano said:I'd like to see how long that would last here in Phoenix, when it was 118 out?
By the way, in the summer here the LOW temp can be over 100, which probably makes it hard for most units to even make much ice in the first place.
Its a good idea. Sorta like a hybrid car, but instead of a battery you are using ice. Also like a hybrid car its expensive, and I'm guessing a substantial payback period.DELInstallations said:You'd be amazed. The chiller lines and ice are housed in super insulated containers, like a stainless oil tank with an inner bladder/tank, if you've ever seen them. The engineering I saw stated somewhere around a 20 hour time with zero input from the outside.
If I get a chance to go back and they have the duct out of the foundation, I'll take a few pics, otherwise it's considered a confined space, no entry without a permit and equipment and you can't break the plane. The vault ceilings are at least 8'-10' below grade, with the floor at least 12' below that. The thermal mass and distance before you even come close to the surface. A chiller doesn't really have to work that hard to get cold enough to start the process.
If you want, I'll see if I can get some guys from the HVAC side of the house to give you the basics on the system.
That's probably the main selling point for commercial customers. Like you, my electric rates are flat, so it's not compelling for me. However, there may be other benefits, and the first directly relates to this thread (which is why I brought up the topic in the first place):lleo said:I was interested about this and found this video that explains the ice banking.
So perhaps it is best described as an electrical demand management, where the peak demand is shifted to off-peak hours.
Overall, the additional freeze/thaw cycle likely has some minimal losses, but pays for utility and consumer by shifting demand.
As a residential customer, I pay the same price regardless when I use the power, the only factor is the amount of power used, that is the more I use, the more I pay even in unit price. So such a unit would not save me any, unless the utility would put it on a separate meter, and manage its curtailment for their purposes. For the amount of power a residential home uses this likely is cost prohibitive.
http://www.youtube.com/watch?v=FnQSURnzPHQ
At least in lleo's case (though he's not in the SW), the cost of boring the hole was a stumbling block. Do you have other datapoints on that?IndyMike said:I've been lurking on this topic for awhile - interesting "additions" in the area of variable speed condensors and control systems. I say "additions" because I have yet to see a study that provides actual numbers on energy savings.
On the latest topic:
Reduced ambient air temperatures at the condensor result in lower system pressures and a direct reduction of power.
Couple of articles that focus on EER vs condensor temperature:
http://www.fsec.ucf.edu/en/publications/html/FSEC-PF-302-96/
https://www.aceee.org/files/proceedings/2010/data/papers/1924.pdf
My turn for a question - Why not ground source heat pumps? Is there something about the soil structure that prohibits their use in the Southwest?
I love these things from a technical perspective - they just don't make much sense in my area where 90% of my cost is heating. Natural gas is still a much better bang for the buck. I would think these would provide a decent ROI in the Southwest where cooling predominates. What am I missing?
