All 5 boards are Zotac 9300 G-E, Intel Q9400s-CPU's, 8 Gig of ram
boot drives are 80GB IntelX25-M SSD's
Thermalright AXP-140 CPU coolers
Thermalright X-silent 140 cooler fans
4 boards running Xenserver 5.6 bare metal with various 32 and 64 bit OS's WIndows and Linux
Board # 5 (on the bottom) runs Openfiler set up with a
3ware 9650SE-8LPML controler setup as raid 6
4- Supermicro M14T 4x 2.5" Hot-swap SAS / SATA Hard Disk Drive Trays
5- Mini Box M4-ATX -HV power supplys to power the boards
2- Mini Box DCDC-USB power supplys 1 configured 5 volt the other configured 12 volt
to power the harddrives
8- 500GB Seagate Momentus 7200RPM ST9500420AS
All stuff into a Thermaltake case with a custom case end panel and motherboard back plane built by me.
This replaced the 4 Dell PowerEdge 2600 power sucking screaming meme's I had running.
