Well, this is the wiring closet... and as it states "Post anything" so here goes
Ok, I have started a small project, that I hope I can pull off with out to many problems <_<
Firstly, I have built a pond and waterfall in my front yard. What I want to do is power the lighting with solar power. All of the crappy "over the counter" solar lights from Home Depot and the likes, are just not bright enough.
So far I have a 12v motorcycle battery, and have ordered a $25 solar panel designed to keep a 12v battery charged.
I have ordered THIS LIGHT, made to be a bike headlamp actually. I chose this one for the inexpensive cost, as well as it is rated to be pretty bright with the 36 High powered LED's, and should work well to illuminate the water fall.
I have a light housing, that you can see in the photo below. It is currently halogen, but am converting it. I am going to take the bike lamp apart, and mount just the LED cluster into that housing, which is waterproof. (I may have to add a diffuser to disperse the light, but will not know that till I get the light, and see just how tight the beam is)
So far all is well...
Now, this is where I need the help..... I need to step the voltage down from the 12v battery to 4.5 volts to power the LED's. I am sure the amperage will need reduced as well.... I think..... I am not sure if I need a potentiometer, or some sort of resistors, voltage regulator or what. I know just about zero about electrical circuits. So, any tips and suggestions are greatly appreciated!
If all goes well, I intend on putting a couple of the solar panels in parallel, using a larger battery, and adding more landscape lighting, as well as possibly wiring up the front porch light to be solar as well, and it will just come on at sunset, and remain on. I will make something similar to THIS, as I have the perfect beam across the the front door that will hide it from view. This will also leave the standard porch light in place, for when more light may be needed ect. (Can you say Pizza delivery!)
Here is a snapshot I took a couple days ago of the pond:
