I know my switch is unmanaged, and I've never used a managed switch. What benefits would i derive if I changed to a managed switch like the DGS-1224T?
I'm sure that the bulk of users never need or even want managed switches. However, for those of us who like control over things (which seems to be almost everyone who frequents these forums), this may be a subject that a lot aren’t aware of. I'll quickly go over some of the key features of the switch, what they do and how they can be used.
Some of the driving features that made me choose the managed switch is its VLAN capabilities. This allows me to logically segregate the network without the expensive of physically segregating it. I can keep my security system on one network, computers on another, storage (NAS) on yet another, and when I add the capability, video on even another. This lets me prevent communication between networks except between "approved" routes that I define. This means there is absolutely no way in heck that when I have a buddy over he can access my security system via WiFi on his cell phone or laptop. There are many other advantages to a VLAN infrastructure - it's worth a Google.
This particular managed switch allows for QoS tagging - so I can give my XBox360 and VoIP priority in the switching & routing. I can also tag devices that don't directly support QoS, or don't allow you to configure it on the device.
The Link Aggregation feature is very powerful. For larger homes you can have let's say three switches setup in a triangle, so all devices plug into the nearest switch. However, typically there is only 1000mbps over a single cat5E run, with this feature you can trunk multiple lines to get a 2000mbps link - while a single computer/device won't be able to utilize all of this, two concurrent maxed out gbit file transfers will be possible. This is also an awesome way to link an existing 100mbps switch into a gbit environment -- trunking it to 200mbps. Multiple switches linked together (the switch has fiber ports too!) arranged like this can cut latency in 1/3rd rather than running every cable to a central location -- longer cable runs = higher latency.
The Spanning Tree is an awesome feature as well. Take the previous example where the network is setup in a triangle. In a traditional network you can never create a loop; otherwise the network will crash and burn. This feature lets you, where it will send data to the correct switch based on rules -- so in a triangle you are always at most 2 hops away from the end device (local switch + 1 remote switch) -- rather than 3 hops. This also means that one leg of the network can go down (let's say cable gets cut from intruder) - the network will instantly start routing traffic over the working link.
Jumbo Frames seem to be a subject that’s floating around. Not all switches really support it. This switch supports it natively, where it doesn’t eat up internal switching cpu power. For comparison, a switch that doesn’t natively support it will take multiple clock cycles to process a jumbo frame - if the CPU isn't properly sized for the switch your limiting factor in speed could be the switch and not the end devices.
The last thing worth mentioning is the security features. Like WiFi routers let you restrict who can connect via MAC address - a managed switch will let you do the same for wired devices. This lets me prevent anyone from attaching a device I don't know about to my network -- in my case I have roommates and their friends to worry about. This is a stupidly simple thing to setup, and IMO worth it. With more and more people attaching security systems and automation equipment to their networks it is important that huge security holes aren’t left open.
Hope this helps,
Kent
