Hey Ross. Thanks for the repsonse. Don't know which side of the dateline you are on, but it's a nice Sunday afternoon here and I hope your day is just as fine.
I have been interpreting that 100mA maximum as the most current the board can source thru the ttl outputs. That is coming from this statement in the manual
"The maximum current that can be sourced or sinked by one of these outputs at a time is 20mA or 100mA for the whole board." under section
"2.2 TTL Output Port". I am driving my fotek SSRs directly from the 8 outputs, their spec says 7.5 mA draw at 12v, and they can trigger from 3-32v.
rossw said:
I power them from the 12V supply *TO* the webcontrol board, not the onboard regulated supply
So maybe I don't understand what you mean by this. Well, OK, clearly I don't. If you are powering the relay
coils with 12v from the power adapter supplying the board itself, how is that power being switched by the tll outputs, in order to control the relays, and their loads, by PLC? Or do you mean, you are powering 12v
loads, connected to the relay switches, from the 12V supply to the webcontrol board? I'm not trying to do that, all my present loads are 110vac. In the new board, at least 10 of them will be 24vac, a few others 110vac, and maybe a couple 12vdc
Do these relay boards have little ssrs on them that allow the use of some other power supply for the coils, other than directly from the wc8 ttl outputs themselves, and the ttl outputs are just switching the little ssrs?
I agree, the little vr on the board is stressed, and that is my concern, to keep tabs on how much current I am demanding from it. And I am using 9v, not 12v, it's quite hot here and the enclosure doesn't need a significant extra heat source inside it
