Hello,
I'm trying to set up two Simply Automated UPB I/O devices for my garage openers. I've downloaded UPStart and having it working with my programming HAI UPB PIM. After reading the PCS Bulletin Omni App Note 200, it states that my "UPB Network Address" should be between 1-250 and needs to exactly match my PCAccess UPB Network Access. This sounds simple.
My problem is when I set up my OP2 for some reason the UPB Network Address was set to 255. (Value found in PCA Dealer software latest version software under "Units/Dealer Settings".)
I've tried changing the Address in PCA to the value of 1, then "Write to Controller", but this address change causes me to lose control of my Units/Lights. I restored the Network Address back to 255 again the system works fine.
Is there more then one place in PCA where I need to change my UPB Network Address? Or do I need to do something differently to use UPStart on with my OP2 and PCA?
Thanks for reading and it you have any insights, I appreciate your help!
