apostolakisl
This 4 sensor state sounds interesting. Can you or someone tell me more. I wasn't aware that Elk had such a thing. I would love to have states of 1) secure (closed) 2) opening 3) closing 4) none of the above (or in other words, open at least partailly and not moving). If that were the case, I could use a single zone to monitor everything I need to know.Hi Lou;
You could do something like that. I'm guessing you would have to poll the zone with some sort of timer and do a value compare to see if the door is rising or falling. The problem is the door opens pretty fast so the poll would have to be at least every second. I guess you could activate this poll to take place only when a command is given to control the garage door (I'm just not sure).
I may have been misleading on my resolution needs in the above post. The Elk has eight bit resolution so it will divide the voltage span into 256 'units' vs say a ten bit which divides the voltage span into 1024 'units'. BUT, when concerning the resolution needed for a garage door's location, eight bits should be more than adequate (unless you are really hard core). I just didn't like the pull up resistor influence and polling/updating using the Elk as an analog input, plus I had other sensors here that needed the ten bit resolution (temp, humidity, salt level in softener, etc...).
I use HomeSeer to read the analog to digital converter via a serial port and place those inputs as devices so it all works out great for me here.
Another thing I'm thinking about is the Elk's abitility to use a four sensor state (forget what it is called) that you might be able to use as well for at least four quadrants of your garage door's location. Best to just get a pot and play around with it a bit.
I do have a Guide to Analog to Digital Converters which might be of some use here as well. B)
This assumes that the garage door motor is a dc motor that switches polarity to open/close. I could easily put two relays on that and using resistors create unique resistances for going up, going down, not moving. Adding a contact closure on the garage that shorts the whole thing out for secure would complete the signal.
