The Cypress chip you posted is not a cheap solution for sure. Do you plan to design your own CPU board? If so, you don't have to post in this sub-forum. This sub-forum is for discussion of WebControl usage.
From you logic, I don't see you really look for a low cost solution, since you insisted us to make WC32 a dedicate Bluetooth controller. Although that cost much less than your Cypress chip suggestion, that cost is still more than WC8 board with a wifi TP-link TL-WR702N as wifi client, that is only $14.99 at newegg web site. Then WC8 controller with TL-WR702N can remotely talk to WC32 over regular wifi network. You can have PWM module or any sensor on I2C and SPI bus, reliably working remotely. If you really worked on wireless communication, you would understand how difficult to have reliable communication. TP-Link wifi client with Wireless-AC1900 based wifi AP RT-AC68U can achieve really reliable wireless communication, much better than those untested suggestion you talked.
WebControl is designed for wide range usage, that is why we support I2C and SPI bus. Talking to I2C and SPI chips in PLC is easy to do. If you want us to develop a dedicate firmware, you have to commit purchase at least 200 boards. We think that is less useful than what we have now. Those Bluetooth module is less reliable than we proposed solution above. But if you paid 200 boards, we would work on the firmware for you, just we will not guarantee your communication result, only guarantee work when two boards with your Bluetooth module facing each other in close distance, due to the Bluetooth module you selected.
