To be clear, the PortStatus never shows "Opened" for the KODI device in Premise Builder? If it shows Open, please paste what port spy shows when you try a few commands.
If PortStatus shows Port(OpenFailed):
I would ensure your server is on the same subnet as the wireless KODI box, that KODI is open on whatever box you are trying to connect with, that your router is set up to allow bridged connections between wired and wireless networks, etc...
Do you have other modules that use the Lantronix UDS10 work around? Is the Lantronix add in known to work on the Premise server? Did you restart the Premise service after adding it?
Also, try pinging the KODI box from your Premise server using a Windows command prompt. KODI should respond to a ping.
I would also wonder if KODI can support more than one connected IP based remote at a time.
PS: you aren't using the webserver part (ok to enable though), that is on port 8080 I think. The Premise module uses TCP on port 9090 or whatever you change the default to. These settings are under Services->Remote Control. Enable both options there.
samgreco said:
I can't get either to import. I get a port reset error on both. So to be sure I could remote control, I installed Kore onto my Android phone and I can control my FireTV with it. So it seems that remote control part of Kodi is working. But I still get: FAILED due to port reset and nothing imports.
Is there anything I need to set in Kodi that I am missing?
BTW, Port Spy just shows 2 block of what appears to be hex as soon as I open it and when I trigger an import I get another 2 blocks of hex and nothing else.
So it seems that Premise is trying to connect and gets no response. I also bound the Kodi device to a PVR in the Home tree to check if it was just an import issue. It's not. None of the controls work either. So I am guessing that it's a setup issue. I have Kodi's Webserver setup with no username or password. Is that an issue?
