I can't get the RCS KPL7 to do the initial handshake with the OmniPro II (3.9) and not really sure how its done?
Presently Im getting the alternating blinking LEDs
Setup in PC Access (v3.15)
Setup / Expansion / Serial :
- Rate "9600"
- Function "Pro-Link"? (is this the correct function?)
Setup / Messages
- "! KL01R[cr]" ( I typed this in as exactly in the "quotes"?) (Switch is set to address 1)
I also tried changing the polarity of the RS485 data wires as suggested in the wiring diagram
Not sure of the process of making the handshake?
- Just having the "! KL01R[cr]" in the Messages section, provides the handshake? How do you send this 'Read Switch command'? ("The LEDs will turn Off after the first "Read Switch commands is received")
-Where is this received? (The 'Read switch' information returned will contain a 'P' character to indicate a power up condition as well as the firmware version)
For Programming: are these the correct Trigger option to use ?
"Scene Switch" / "KPI-PB1" (representing Switch address 1, Button #1)
- Rate "9600"
Setup / Messages
