ddennerline
I received the driveway sensor today and installed. I configured as Aux1, so that NextAlarm can send me email notifications. I tested it a few times, and it worked correctly. There are a few concerns.
- I am not sure why the sensor doesn’t have the txid wireless serial number implanted on sticker. This leads to second issue.
- Enrolling the device is rather clumsy because you have to remove the battery and hold the device while holding odd shaped sensor body. I nearly dropped the sensor while trying to manually learn the device into Elk. The sensor body is made of plastic. They really should have put a small button or made sure the txid label was present (maybe I missed finding the txid?)
- The entire device is plastic – including the mounting parts. I hope the sole reason is not reduced price – at least they could have included metallic ground stake. I suspect some of the parts have to be plastic (or other non-metallic material) in order to not interfere with accurate detection. I wonder if you can buy individual plastic parts. There’s no way that plastic stake can be driven into my clay soil without digging up the ground. The soil would then not be suitable as an anchor.
- Mine didn’t come with a post mount – will have to contact manufacturer.
