My current 110v smokes are approaching 10 years old. I'm undecided on GE 350 / 350CX smoke alarms and retrofitting 2 wire smoke detectors with integrated sounders. I want notification when I am away that a smoke has gone off, but am worried about inspection when I sell the house.
I looked at the codes and in short it states smoke alarms must be 110v and interconnected and smoke detectors must be connected to a monitored panel. With smoke detectors the future owner is stuck with paying for monitoring or putting back the 110v smokes. With the GE350CX I have no supervision, the possibility that the relay doesn't work, and no clean me notification.
If I go with the 2 wire smokes it looks like I need the following to interface with the HAI OmniPro II.
GE 429CST Smoke Detector, 2-Wire, Sounder, Heat, 12/24VDC, UL
ESL 405-03 Polarity Reversing Relay
ESL 505 CleanMe Module / 2 to 4 Wire Converter
If I don't care about the clean me notification do I need the ESL 505? The HAI manuals states compatibility with the GE 429AT which looks to be the same without the sounder. Obviously the panel can't reverse the polarity out of the box so the sounder won't go off until I add the ESL 405-03.
When reusing the existing 110v wire what is the best method to allow for reconnecting 110v smoke alarms? Should I remove the wire from the breaker, cap it in the breaker panel and first smoke junction box, and run the 18/2 firewire to that box from the HAI panel? Or is this considering mixing high and low voltage even though the wire is capped? Do the 14/3 wires fit under the smoke detector terminals or if I have to pigtail are standard wire nuts connecting to 18/2 sufficient?
Obviously if I went the GE350CX route I would be mixing high and low voltage, but I would just remove the wire when selling the property. If I had to revert the 2 wire smokes then I need to purchase new smokes to replace them as my current are past 10 years old, which is an additional expense.
It looks like I also need to check every smoke junction box to make sure they are wired in series. It sounds like with 110v smokes it is possible to branch off two directions from a single detector. If that is the case then I can't install the 2 wire smokes without rewiring it to be series?
