With enough relays, you can do pretty much anything.
So, the first pulse turns the actuator on (call that the forward direction). The second pulse reverses the direction. What happens next? Is there a third pulse to turn it off? Or does a limit switch turn it off?
Once it is off, does the next pulse turn in on in the forward direction again? i.e. when it turns off, there is an implied reversal back to the forward direction.
What should happen if power is lost mid cycle? When power is restored, should it continue in the direction it was going in? Or default to the forward direction?
Finally, how long are the pulses from the OP2? Milliseconds vs seconds could make a difference in the design. If the pulse is too short, it might not be able to trigger a relay directly.
