I've been interested in HA for a long time, but there are always more important things to spend money on, right?
Most of the posts here are over my head and much farther than I'd ever get in this house, but I think you guys could help/answer a question for me pretty easily.
I've got an old 2 story house (1967). In the spring and fall when the temps are nice, during the day, the downstairs will stay a great temp. Since that's where the thermostat is the HVAC system stays off. The problem is that over the course of the day the upstairs heats up until it's uncomfortable. The answer is to turn the fan to on to keep the cool and warm air circulating. The next problem is that I would prefer to not have that fan running for days or weeks.
I've got a plane Jane AC unit with a 7 day programmable thermostat. The AC is nothing special, not a split system or multizone or anything like that.
I'm reading about the 1-Wire stuff now and will be installing some weather sensors including at least 2 temp sensors inside the house. I was thinking that it should be fairly easy to set up a 1 wire system with a temp sensor upstairs and downstairs. If the upstairs temp hits a certain threshold or the temp differential between up and downstairs hits a certain threshold then the system could use a relay or switch to turn the fan for the HVAC system on. I assume that I'd need a diode or something to allow the thermostat to still function normally. I assume that I wouldn't want both the 1-wire system and the thermostat to both be on and the power to flow where ever. That's where a diode or two would come into play.
So, how easy do you guys think it would be to set something like that up? What are the pitfalls (other than frying my AC and burning down the house B))? What do you think I'd need/How would you set it up?
Thanks in advance
Thanks in advance
