I have line powered, interconnected smoke detectors but want to add detectors tied into the existing alarm system. My only question is where? The existing detectors are in each bedroom and outside each bedroom (in accordance with local rules). I could place one in each of these locations but that seems like overkill. I am thinking in the equipment rooms - I have two in walkout basement, one has furnace on one side of the house and one has gas water heater, and electronics "closet" on the other side. Then one for the main (only other) floor. That seems like a reasonable minimum. I have 6 existing with two bedrooms on each floor. Could also put one in garage but may want heat sensor there.
Any issue interconnecting 4 wire smokes with heat sensors? Recommendations on models and where to get? I have a couple 20 year old unused 4 wire units (think they came from radio shack). Any issue with mixing 4 wire brands or age? I have seen some places state they should be replaced after 10 years.
Any recommendations on locations? Have decided not to connect existing detectors to the panel for fire, although I might connect them some other way for personal notification and automation.
