I'm working on setting up some 4-wire smoke detectors in a pretty large house (11 total smoke detectors).
Planning on using the System Sensor i4 CO / Smoke Detectors. They have a module that separates out the fire alarm and the CO alarm for the panel, which is nice.
I need the smokes / CO detectors from different parts of the house wired into different zones, so the panel knows a rough idea of that alarm was tripped. That part is easy enough, but to satisfy local code, I need to have all the alarms go off when one is tripped.
Page 3 of the document below has a wiring diagram. It looks like I can make the alarms go off by sending a bell output to the module.
https://www.systemsensor.com/en-us/Documents/i4Series_Module_Manual_I56-3871.pdf
With an Elk M1 gold, I'm trying to figure out what outputs I'd need to wire this module in to in order to trip a seperate "Bell" output for the smoke and CO.
Anyone done this before that could share some experience?
