I have a Omnipro2 panel and I am having an issue adding any IP cameras to view using snaplink.
I did not have the HAI Camera Server or any HAI branded IP Camera.
I am using a Dahua IPC-HFW2100 IP Camera
I have set up the Sub-Stream on the camera to MJPEG (Main stream is H.264)
I have configured the following ports on the camera all for port forwarding and they all are open when tested;
TCP: Port 40000
UDP: Port 40001
RTSP: Port 40002
HTTP: Port 40003
IP address of camera is 192.168.1.230
I have set up a LOCAL account on my Snaplink software using iPhone (HAI Panel 192.168.1.90)
So I am trying all this on my local network.
The only Camera settings asked for in the Snaplink app are the following
Address
Username
Password
Camera Type
I have cycled thru all combinations with no success
Tried all these addresses each as MJPEG and JPEG
192.168.1.230:40000
192.168.1.230:40001
192.168.1.230:40002
192.168.1.230:40003
Has anyone had success using a generic IP Camera?
which port should work?
TCP: Port 40000
UDP: Port 40001
RTSP: Port 40002
HTTP: Port 40003
TCP: Port 40000
UDP: Port 40001
RTSP: Port 40002
HTTP: Port 40003
Address
Username
Password
Camera Type
192.168.1.230:40000
192.168.1.230:40001
192.168.1.230:40002
192.168.1.230:40003
TCP: Port 40000
UDP: Port 40001
RTSP: Port 40002
HTTP: Port 40003
