lupinglade
1) Any Mac that can run 10.7 is currently supported. I would recommend a machine that can run 10.8 though as we may require 10.8 in the future.
2) The GUI is a web based GUI, but its live like a web application. It is usable from Android, yes. You can also customize it to your needs using CSS/HTML/JavaScript/etc.
3) The GUI would run over Chrome.
You start HH on your Mac and add your controller. You can then connect to the Web Interface on port 9399. Ie. by going to http://ip-or-host-name-of-your-mac:9399/
There is no trial version available.
If you just want to use the existing UI or make minor changes to it, that can be done quite easily and doesn't really require much if any programming knowledge.
To be able to create custom UIs for HaikuHelper its best to have some experience with CSS/HTML/JavaScript.
